Creates a maintenance domain (MD) in the DNS name format and assigns an MD level to that domain.
name |
Assigns the name you want for this domain, using the DNS name format. Enter alphanumeric characters for this format; the maximum is 43 characters. |
level |
Specifies the MD level you are assigning to this domain. Enter a value between 0 and 7. |
N/A.
You can have up to 8 domains on a switch, and each one must have a unique MD level.
You assign each domain a maintenance domain (MD) level, which function in a hierarchy for forwarding CFM messages. The levels are from 0 to 7; with the highest number being superior in the hierarchy.
5 to 7 for end users
3 and 4 for Internet service providers (ISPs)
MEPs with intervals 3 and 10 cannot be created in this domain as the domain name format is of dns type.
The following command creates a domain, using the DNS name format, named extreme and assigns that domain an MD level of 2:
create cfm domain dns extreme md-level 2
This command was first available in ExtremeXOS 11.4.
